Ingatestonian
Feb 13, 2026Follower
Resetting Orbi RBS50Y outdoor satellite
I've bought a second-hand RBS50Y and want to add it into my existing mesh.
However, from reading the manual, once the satellite is synced it needs resetting to be able to sync it to a new device.
How can I reset the device in order to allow it to sync again? The manual is not really clear, just mentioning the reset button - is that sufficient? Do you just press it briefly and that's it?
press and hold reset for 7-15 seconds while its powered on. The status light should change color and blink when held long enough.
Is it compatible?
- https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
