goldbondx
Nov 04, 2018Apprentice
Restoring ORBI RBR50 router configuration file to RBR20 router - Possible?
I just purchased a new Orbi RBR20 setup (1 router + 2 sat) and I want to dump my old RBR50 but keep my existing config.
Is it possible to use the RBR50 router config file on the RBR20 route...
goldbondx
OK next question would be ..
Can I use same SSID and password for wifi at least? I am going to guess no?
I have a bunch of IoT devices that I really don't want to have to add again..
Nov 04, 2018Guru - Experienced User
Yes you can. You can use same SSID and PW as before with other system. Aslong as other system isn't being used.
