dstranathan
Aug 17, 2018Apprentice
Returning my CBK40 System
After 3 months of struggles, I am finanly giving up on my CBR40 modem/router (and CBK40 kit). I have had Spectrum technicians out so many times that they have told me they wont help me until I use th...
Aug 17, 2018Guru - Experienced User
You might get your own stand alone modem instead. Find out what BYOM is supported on there system.
See if any one of these is supported, if so, then you could get a Orbi router only kit:
- dstranathanAug 17, 2018Apprentice
I considered it, but at this point if I plan to go mesh again, Ill likely try Eero next. Had Google Wi-fi and wasnt happy with it.
My Orbi experience has been horrible since the day I got it. Even registering it with Spectrum on day one was a trainwreck.
While the CBR40 is "supported" by Spectrum, its actually on their "Supported but not recomended" list. The Spectrum logo that appeard on the original retail box packaging early in 2018 (before it shipped) has been removed. Yes - the Spectrum logo is gone (my box arived vis UPS and I was suprised - and worried - that the logo has magically vanished on the finish product).
All of these things sugest to me that the CBR40 is not-ready-for-prime-time (or maybe Spectrum isnt too pleased with the specs/performance, and is treating as such etc).
No offense to NETGEAR (I have had nice routers and switchs in the past), but Im going to move on...
- FURRYe38Aug 17, 2018Guru - Experienced User
Well the CBK40 differs from the Standard RBK systems. I presume you may have had a bad kit. Or something between your ISP and this CBK40. I've been enjoying my kit since day one, however I had Cable1 register it as a CM700 since at the time, C1 hadn't posted the CBK40 officially on there list of supported modems when the CM700 was.
I set up my friends RBK50 system a few months back. Loves it and working great for him:
Good Luck.
- vkdeltaAug 20, 2018NETGEAR Employee Retired
Please PM me.
- dstranathanAug 21, 2018Apprentice
I was ready to sell it on eBay after 2+ months of inconsistent behavior. My ISP (Spectrum) gave me a new Arris OEM router and modem to get me back up and running while I reseached what to buy next. I tried Google and didnt like it. Considered Eero and Ubiquity but they didnt have all the features I wanted and they were pretty expensive.
I did more research and decided to to try Orbi again - but with a Spectrum modem.
I got a RBK50 kit (RB50 router and RS50 satellite).
To my surprise - the EXACT same problems started again. Then, after pouring over every step of my configurations and every inich of my cabling and topology, it hit me like a ton of bricks - The problem has been isolated to Ethernet backhaul.
So I returned the brand-new RBK50 kit to Micro Center (only had it for 2 days), and re-deployed the original CBK40 kit again from factory (and removed my eBay ad).
I'm back where I started - but now I know EXACTLY what the issue is!
Its really bizare behavior. It looked like a WAN issue, but sure enough, it is in fact caused when I plug in a satallite into Ethernet (reproduced with both a RBS20 and a RBS50). It took me a long time to figure this out. I feel dumb now, but the symptoms always look like it was on the WAN - not the LAN.
My home is brand new. Moved in December 2017. Brand new Cat5e in all rooms with home-runs back to my utility/storage room in my garage when my coxial is located (and my routers/modems/etc). I had a 3rd-party network technician tone-out the cables and they all reported OK. All other cables (patch cables etc) are brand new and I have replaced them all at least once during troubleshooting.
If I plug a computer or game console into the RJ45 plug where I typically plugged in my Orbi satlelites (master bedroom wall plug), all the systems run fine (speed tests are great). But as soon as I plug in an Orbi Satallite into that same RJ45 wall plug for backhaul the whole system goes down.
Firmware is up to date. Done multiple factory resets etc.
