Endorphine71
Sep 25, 2016Apprentice
Ring Door Bell
Just setup my Orbi system and didn't haven any trouble with over 15 different devices, except my Ring Door Bell. No matter what I do it won't connect to the Internet. It connects to Wifi and get...
- Jul 08, 2017Solution: Hi I have just spent the day troubleshooting Ring and Orbi and have found out the following.
If your Orbi is set to a 2.4ghz wireless channel over 11 the Ring doorbell will not see your wifi. As the wireless channel is auto selected this would explain why some users have no problem and other users cannot connect.
Disabling/enable mu-mimo and beamform will sometimes cause a channel change hence why it helps some users. But it is nothing to do with the problem and can be left on or off.
So if you want your Ring doorbell to work select a wireless channel below 11 in your Orbi wifi conf.
Dima1007
Sep 26, 2016Aspirant
Just to share my experience: I spent hours trying to connect Ring. Then I went to wireless settings in advanced setup of Orbi and disabled the beamforming. Ring connected right away. I enabled the beamforming back and so far for the second day the doorbell is staying connected.
Endorphine71
Sep 26, 2016Apprentice
Thanks for the tip.
I will give it a shot and let everyone know if it works.
- Endorphine71Sep 26, 2016Apprentice
Well I just tired turning off the implicit beamforming and it made no difference. I saw that the Ring was getting an IP address in the router table.
For fun turned off the Orbi, fired the X6 back up with the old settings and tired connecting it that way. Again, it would get an IP address but fail to "connect to the Internet".
Either it is faulty or my account is messed up. I sent them another support e-mail to see if they can check it. Hopefully they will have an idea of what to do or it is going back to Costco.. LOL.
