Endorphine71
Sep 25, 2016Apprentice
Ring Door Bell
Just setup my Orbi system and didn't haven any trouble with over 15 different devices, except my Ring Door Bell. No matter what I do it won't connect to the Internet. It connects to Wifi and get...
- Jul 08, 2017Solution: Hi I have just spent the day troubleshooting Ring and Orbi and have found out the following.
If your Orbi is set to a 2.4ghz wireless channel over 11 the Ring doorbell will not see your wifi. As the wireless channel is auto selected this would explain why some users have no problem and other users cannot connect.
Disabling/enable mu-mimo and beamform will sometimes cause a channel change hence why it helps some users. But it is nothing to do with the problem and can be left on or off.
So if you want your Ring doorbell to work select a wireless channel below 11 in your Orbi wifi conf.
Chris_Sp
Feb 26, 2017Tutor
Yeap, same problem mumble mumble mumble
- IneedamonkJun 04, 2017Tutor
Same problem 1 flood cam 2 stick up cameras, all went down and can't see my new Orbii network. Changed SSID and PWD when setting up Orbii. Every other device connects no problem. When standing in front of the cameras I can connect to the Orbii network with my phone and tablet when standing in front of the camers so I know the signal is good.
Going to start moving around the satellites, then will disable beamforming. I read somewhere that Ring only uses 2.4ghz but on a triband system that shouldn't be a problem.
Really weird to see everything go down and stay down all at once.
- DarrenMJun 06, 2017Sr. NETGEAR Moderator
Hello Ineedamonk
Did you ever get your cameras back on the network?
DarrenM
- IneedamonkJun 07, 2017Tutor
No. We are still working on it. I've taken everything down but one camera. The ring has much more trouble seeing the network then my phone does. Not sure why Orbii has this difficulty. Continuing to troubleshoot with Ring folks.
