wegunterjr
Jun 01, 2019Guide
ring doorbell 2 hasn't been able to connect in months RBR50 and 2 satellites
Hardware Version RBR50 Firmware Version V2.3.1.60
When i first got the ring doorbell 2 it was able to connect to my orbi network. Since some update in January/February it has not been able to connect. A little frustrated.
I actually find that a lot of my IoT devices do not work well with Orbi.
Any thoughts?
I have verified I am not on channel 13 or anything strange.
- ekhalilMaster
This can either be a radio issue or an IP network issue:
- I think that the Ring Dorrbell 2 uses only 2.4 GHz radio. What 2.4 GHz channel are you using in Orbi?
- Is Orbi working in Router or AP Mode? What type of ISP modem/Router are you using?
- I am using RBR50,: so it has the main router and two satellites. The channel is 5 for 2.4GHZ.
Try setting manual channel 1, 6 or 11 on 2.4Ghz
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).Do a full factory reset on the RBR and setup from scratch.
wegunterjr wrote:Hardware Version RBR50 Firmware Version V2.3.1.60
Any thoughts?
