Danield340
Feb 11, 2017Guide
Ring video doorbell pro w/Orbi
I purchased the Orbi system (RBK50) to kill a wifi dead spot at my front door for my ring video doorbell pro. After setup the ring video doorbell connected to the satellite unit which is within 10ft ...
st_shaw
Feb 11, 2017Master
If the doorbell is working fine, you can probably just leave it. If it's not working well, then you can try reducing the power on the Orbi, especially the 2.4 GHz band. That will drop to -70 RSSI down farther, and should help prevent the doorbell from switching.
- Danield340Feb 11, 2017Guide
It's back on the satellite ATM. It seems to be switching back and forth no clue why, no conditions have changed. The app informs me that the signal is bad and it degrades the video quality when connected to the router.
Is this orbi web gui compatible with Chrome?
- st_shawFeb 11, 2017Master
Did you try my suggestion of reducing power on the Orbi?
Since i'm already at -70 I probably don't have to lower it much, right?
