michel1918
Jan 31, 2019Tutor
RKB50 router light is purple (not the sattelite)
In the 3 days I own the RKB50 the router is having a purple light, which I understand means that there is no internet connection.
However, there is an internet connection because everyone in the ho...
ekhalil
Feb 01, 2019Master
You probably have the ISP Router connected to Orbi's LAN port? In AP Mode you can have the ISP router connected to either the WAN or LAN ports since these are -somehow- bridged in AP mode. However, using the LAN port for ISP Router will cause the router to light magenta.
Please move the cable to the yellow WAN port if you don't like the beatiful magenta light. :)
