michel1918
Jan 31, 2019Tutor
RKB50 router light is purple (not the sattelite)
In the 3 days I own the RKB50 the router is having a purple light, which I understand means that there is no internet connection.
However, there is an internet connection because everyone in the ho...
michel1918
Feb 01, 2019Tutor
I already had it attached to the yellow port.
I looked again at the docs and read that purple blinking means no internet connection, but I have a steady purple light.
ekhalil
Feb 01, 2019Master
The router seems -for some reason- not sense the cable in the WAN port. Can you please try to swap the cable with another.
- michel1918Feb 02, 2019Tutor
Swapped cable. No result.
Also still didn't find any clue what a SOLID purple light means
- FURRYe38Feb 02, 2019Guru - Experienced User
Was found in the link provided:
"Solid magenta. Your Orbi satellite ring is solid magenta for 10 seconds if it is unable to obtain the IP address from the router."
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
I have a Arcadyan experia box V8. It's a modem, not sure if it is a router too....
