michel1918
Jan 31, 2019Tutor
RKB50 router light is purple (not the sattelite)
In the 3 days I own the RKB50 the router is having a purple light, which I understand means that there is no internet connection.
However, there is an internet connection because everyone in the ho...
Feb 02, 2019Guru - Experienced User
Yes ALL wifi on the modem needs to be disbled. After disabling, power OFF the modem and Orbi for 30 seconds, then power ON the modem, then power ON the Orbi. The Orbi in AP mode should be WHITE on top first, then Pink, then go BLUE then OFF if its connected correctly.
michel1918 wrote:
Yes, that's the one I have.
Option 1 and 2 sound a little too technical for me, option 3 is the one I already did, but I didn't "disable all wifi radios on the modem". Does it matter whether the modem wifi is still on or not?
michel1918
Feb 04, 2019Tutor
Hi,
Thanks for all your help, but this product is going back to the store.
Way too many things to do before I get it working, also too picky on the distance between the sattelite and the router.
Thanks again for the help.
- FURRYe38Feb 04, 2019Guru - Experienced User
Good Luck.
- michel1918Feb 18, 2019Tutor
Thinking about buying a 3-node setup, and then setting it up with a wired backhaul.....
- ekhalilFeb 18, 2019Master
Good choice! :)
- FURRYe38Feb 19, 2019Guru - Experienced User
Make sure you use non managed, non green ethernet switches if you choose to go wired back haul with lan switches in the mix. :smileywink:
