michel1918
Jan 31, 2019Tutor
RKB50 router light is purple (not the sattelite)
In the 3 days I own the RKB50 the router is having a purple light, which I understand means that there is no internet connection.
However, there is an internet connection because everyone in the ho...
Feb 04, 2019Guru - Experienced User
Good Luck.
michel1918
Feb 18, 2019Tutor
Thinking about buying a 3-node setup, and then setting it up with a wired backhaul.....
- ekhalilFeb 18, 2019Master
Good choice! :)
- FURRYe38Feb 19, 2019Guru - Experienced User
Make sure you use non managed, non green ethernet switches if you choose to go wired back haul with lan switches in the mix. :smileywink:
