ClairRowland's avatar
ClairRowland
Follower
May 21, 2020
RMR40 Orbing
Is it possible to ever get help from Netgear? We purchased an RMR40 Orbi Router and satelitte system wh had the system for 4 months the the router stopped working. We paid extra for priority support. Still unable to see where this kicks in as everytime we called support we went through the general 30 minute wait on a standard help line.
When we eventually got through the support technition confirmed what we had already done several time and concluded the same result that we required a replacement.
We paid an extra £20 to get next day delivery as you would due to no internet connection without the router. We complieted all the nessesary documentation and despite this we still haven't recieved the item nor anyone who follows the case through. Instead we got several different support agents all with conflicting information?
So currently I can say I'd reccommend Netgear as the servce follow up and communication is appauling.
Hopefully these messages get read by Netgear staff and someone will have the curtesy to contact us to resolve this poor service.
  • FURRYe38's avatar
    There is not RMR orbi.
    There is newer FW available for the 40 series RBK4:
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi ClairRowland
    Please send me a private message with the support case number and/or RMA number by clicking on this link.
    Blanca
    Community Team
