SimonBelgium
Oct 15, 2018Guide
Rogue AP with unknown MAC Identifier
I've been using the RBS50+RBS50 for some time now, and a while ago one of my security devices alerted me there was a rogue AP in the area broadcasting on my SSID.
When I researched the MAC identifi...
- Oct 16, 2018
Those back haul MACs are hidden as there is not need for any user use for them and is only used by the Orbi system. Since the system is designed to be automatic and mostly simplistic configuration, theres no need for displaying of some system settings and configurations. This is how it works for MESH and Smart Connected features. You might contact the Mfr of your security device to ask about how they detect and handle MESH and Smart Connect wifi router systems. Probably a false positive on there part.
SimonBelgium wrote:
Seriously? Why would they not list those in the web interface?
How can I identify which ones are the actual "hidden" MACs? Yes they are VERY close to the actual MACs
Oct 16, 2018Guru - Experienced User
SimonBelgium
Oct 17, 2018Guide
Thanks guys,
Is there any documentation on the use of those virtual MACs for the backchannel?
- FURRYe38Oct 17, 2018Guru - Experienced User
There isn't from what I can tell.
- RickDiasOct 19, 2018Tutor
When I installed the new V2.2.1.210 firmware on 10/12/18, I started seeing a weird device showing up. The Orbi's Attached Devices admin page identified it as a Cadant device, and when I checked the IP address it matched the range for a Comcast server upstream of me. At the same time I started having a bunch of DHCP issues, with my SB6141 modem trying to supply some 192.168.100.X addresses on the network and the Orbi supplying the expected 192.168.1.X range. I power cycled everything (cable modem, Orbis and ethernet switches) and haven't seen the Cadant device for a few days.
Good luck!
SB6141>RBR40>(wired)RBS40 w/30+ devices attached total
- FURRYe38Oct 19, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001If you see this again, try this next time:
Good luck!
