PaulB2019
Apr 29, 2019Initiate
Rollback/Uninstall firmware update 2.3.1.48
How do you uninstall firmware update 2.3.1.48? Ever since this update was applied 2 days ago my system is not working correctly. I have reset system to factory default settings but this does NOT ...
Apr 29, 2019Guru - Experienced User
Whats not working correctly? Wireless? Wired? Internet access? Need more details. Others have v48 loaded and is working for them.
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
PaulB2019 wrote:
- How do you uninstall firmware update 2.3.1.48? Ever since this update was applied 2 days ago my system is not working correctly. I have reset system to factory default settings but this does NOT rollback the firmware update.
- PaulB2019Apr 29, 2019Initiate
So I think you are missing the point. Regardless of all the questions you asked the point is that everything worked fine before this update! All I was asking (and still asking) was how to roll it back/or uninstall? There are quite a few other posts of folks that had ssues with this update as well so it definitely seems that there was an issue(s). As to what is not working, the satellites lose their connection to the router and all connected devices seem to lose internet connectivity regardless of which satellite/router thery are connecting to. Powering the router off/on seems to correct the issue but only temporarily. After several minutes of waiting for everything to come back up the issue reappears within10 minutes. I will stress again that the ONLY thing that has changed is that the update was applied.
- FURRYe38Apr 29, 2019Guru - Experienced User
Maybe answering some of the questions and trying some of the suggestions may help your situation. Has helped others. v48 works for me and others. Sometimes Orbi needs some additional adjustments to help it work. Also there are other factors that can cause problems with Orbi as mentioned is the suggestions may help. Roll back FW may not help and prior version may have only been covering up the real issue.
Try this however if you wish:
https://community.netgear.com/t5/Orbi/Orbi-Router-Auto-Firmware-Update-Switch/m-p/1743269#M60404
Good Luck.
