PaulB2019
Apr 29, 2019Initiate
Rollback/Uninstall firmware update 2.3.1.48
How do you uninstall firmware update 2.3.1.48? Ever since this update was applied 2 days ago my system is not working correctly. I have reset system to factory default settings but this does NOT ...
SW_
Apr 30, 2019Prodigy
Hi PaulB2019,
PaulB2019 wrote:
- How do you uninstall firmware update 2.3.1.48? Ever since this update was applied 2 days ago my system is not working correctly. I have reset system to factory default settings but this does NOT rollback the firmware update.
You can rollback to a previous version by re-installing your previous version over the current version. Then you might want to lock it down by disabling firmware auto-update. All supported firmware versions can be downloaded from here.
To (re)install firmware, head over to ADVANCED Firmware Update page and select the Manual Update. Then upload the firmware version you want to install. Repeate the same steps for all the Satellites. To access the Satellite UI, points your browser at its IP address.
Good luck!
