ob-1
Oct 20, 2018Aspirant
Router and Orbi setup
Hi there,
I have purchased a basic modem: http://amzn.eu/d/3OY9rSj and an Orbi RBK50: http://amzn.eu/d/dDnRozS
What is the recommended configuration in regards to using the modem as a mod...
- Oct 20, 2018Thanks, I’ll go for that option if recommended.
For reference: https://kb.netgear.com/30773/How-to-set-DM200-into-bridge-modem-only-mode
Oct 20, 2018Guru - Experienced User
The modem you selected seems to be a modem only so no router built in. So you can use the Orbi in router mode.
ob-1
Thanks for your reply.
The DM200 will work in both modem only and (by default) modem/router mode.
So original question still stands ...
- FURRYe38Oct 20, 2018Guru - Experienced User
the DM200 is a modem only. I don't see any information regarding it having a built in router.
https://www.netgear.com/support/product/DM200.aspx
https://www.speedguide.net/routers/netgear-dm200-broadband-high-speed-dsl-modem-3808
At any rate, the DM when used AS a modem, you can use the Orbi in router mode. Which is the perferred method and configuration for the Orbi syetem.
- ob-1Oct 20, 2018AspirantThanks, I’ll go for that option if recommended.
For reference: https://kb.netgear.com/30773/How-to-set-DM200-into-bridge-modem-only-mode- FURRYe38Oct 20, 2018Guru - Experienced User
Good Luck.
