RegDawg
Apr 19, 2018Apprentice
Router and Satellite Placement
Is there a recommended distance the router and satellite should be placed from each other?
nicholb
Apr 19, 2018Luminary
Straight distance recommendations are tricky. There is a dependency on how many walls and floors the signal goes through as well as the material used. For an extreme example plaster wall with a wire mesh in it would require them to be much closer together whereas clean line of site would be much further apart.
Ideally you want to put the satellite at the edge of the strong reception area of the router.
