Rewai
Feb 11, 2017Initiate
Router doesnt recognize external USB hard drive
I want to connect my Apple TV 4, to a USB hard drive attached to my Orbi. The physical connection is fine but getting the Apple TV to recognise it is another challenge. I had it working brilliant...
- Feb 11, 2017
What I've read here so far is that the USB is not functional at this time. Not sure if there are plans, or capabilities, for this in the future to be honest - I believe there would need to be firmware logic to serve the disks as a shareable device.
If you're looking to serve some storage, you may want to consider finding a device with ethernet connectivity. Seagate and WD have several inexpensive options. USB 2.0 is pretty slow and you'll get much better performance via ethernet
MarkC1024
Feb 11, 2017Luminary
Rewai
Feb 12, 2017Initiate
Thanks very much Mark your reply is very helpful and saved me hours.
What a funny thing to release a product with a USB port and not supporting it! Weird.
Appreciate the pointer to the ethernet solutions.
