radtech48's avatar
radtech48
router faster than modem combo?
I just installed the Orbi CBR40 modem/router combo with 2 satellites. fairly easy to install, but upon doing a speed test, I'm only getting around 215mbps. Before installing this, I had purchased an installed just the router with a satellite, while using a spectrum modem. I was getting around 480mbps when using the orbi speed test on my phone app. Anyone know why this is and what I can do to increase my speeds? To be frank, I wasn't unhappy with Spectrum's equipment, but somehow was  under the impression that I was paying for their equipment. I found out today when I called to activate the new modem, that I was not paying extra for it. In any case, I thought maybe I could get better speeds with the Orbi product and I think I am. I can't remember what speeds I was getting with Spectrum, but it was nowhere near 400mbps.
This Orbi states that I could get up to 2.2gbs. I'm hoping to get gb service here soon and am worried that this won't cut the mustard. I have 90days to return to costco, so there's that good news. TIA.
1 Reply
  • FURRYe38's avatar
    What are the speeds if you use a wired PC and Ooklaas Speed Test app?
    Ensure the ISP has checked the signal and line quality up to the modem/router.
    Be sure there are no coax cable line splitters in between the ISP service box and the modem.
    Ensure your using good quality RG-6 Coax cabling.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Has a factory reset and setup from scratch been performed since last update?
