Ploppy1
Mar 25, 2021Aspirant
Router not working after 3-23-21 update
Per Netgears suggestion, I updated the firmware on my Orbi system/router on March 23rd, 2021. Since then, the router will periodically stop working and disconnect from the internet/modem. Message in O...
vajim
Mar 25, 2021Master
Ploppy1 wrote:
The update was recommended via the Orbi app. I know in the past, via press releases from Orbi and other tech websites,
not updating the firmware can pose a huge security risk. ALL the connection problems started occurring AFTER I updated the firmware. Everything was working fine before the firmware update.
Any recommendation from either the pc login or app is just that, a recommendation. You are NOT required to update.
Ha_Ku_Na
Mar 25, 2021Luminary
vajim wrote:
not updating the firmware can pose a huge security risk. ALL the connection problems started occurring AFTER I updated the firmware. Everything was working fine before the firmware update.Any recommendation from either the pc login or app is just that, a recommendation. You are NOT required to update.
Correct, it is not required to update the firmware, but the fact of having security issues with older firmwares is a good reason to update.
And it is also correct, the latest firmware has a bug (WITH ENABLED "Traffic-Meter") which can lead in an unstable system.
But this bug is also present in older firmwares (looks at least from 2.3.5.36 upwards), see:
If there is a suitable workaround to fix a current issue, then there is no need to downgrade the firmware.
Anyway, it is up to the preferences of the users to update or not.
- vajimMar 25, 2021Master
Thanks
Excellent write up.
