GTPprix
Mar 06, 2018Star
Router solid Magenta in AP Mode - Fix yet?
So in the interest of not being "that guy" I've just read through basically every post I can find concerning this and still have no resolution that I can find.
I've got an Orbi Router in AP mode with the cable plugged into a network port (not WAN) and everything works just fine however I've got the solid magenta light on top. Is there any way to fix this IE suppress the light LOL
- st_shawMaster
Plug your cable into the Orbi WAN port and the light will go out.
That doesnt seem to work in my configuration, the Main Router(AP in my case) is plugged into a large Cisco switch not a cable modem.
- st_shawMaster
I don't know why that would matter. The Orbi instructions say to connect to the Yellow Internet (WAN) port in AP mode. My Orbi is in AP mode, and the Yellow Internet port is connected to a Ubiquiti switch, which is then connected to my router.
Maybe power-cycle things after moving the cable to the WAN port?
If you have to leave your cable connected to a LAN port, I read that you can connect anything to the Orbi WAN port and the light should go out, as long as a link is established.
Well if anyone is on the v2.0.x.x version of FW, ethernet backhail doesn't work right. IT's supposed to work on v2.1.x.x however we all know that version was pulled.
I recommend waiting for the next official release as everything should be better then. You could call in to NG support and ask them if they have a beta that you can test.
- swiederTutor
Just picked up an Orbi Systems (RBR40 and two RBS20s). Its a finicky set up. I had to factory reset once. Running 2.1.4.16 software. I am using the Orbi set up as APs with wired Backhauls on the satellites and a fixed IP address.
Had the Magenta Ring on my AP since it was connected to my network switch via a LAN port. I read that the Internet WAN port become just another switch port when in AP mode. Wired backhauls did not work if the AP was connected via the WAN port. I plugged my PC ethernet port into the WAN port and the Magenta ring turned off.
I also had an issue with one of my Satellites in a "Config Sync" state. I dettached the wired backhaul, let it sync via WiFi and than reattached the wire. The connected devices screen now shows everything as "Good"
My kits includes an RBR40 and two RBS20 which seems like a Best Buy special. Will the AP run the same sofware as other RBRs?
Lastly, I read good things about the 2.2.x software. How to I get on the Beta for the newest release?
You have to connect the RBR WAN port to the other LAN source for the top LED to turn off when in AP mode.
ALL RBRs have there own FW based on model #s. 50s differ from 40 series and so on.
You can apply for the beta here:
- swiederTutor
Can anything be connected to the RBR WAN port? If I connect the WAN port to my backbone switch than the Wired Backhaul connections stop working. I tried putting a PC on the WAN port, but than one of my Satellite RBS20s dropped off.
These devices are very finicky! Not sure I will be keeping them. I have had the set up for 3 days and have lots of intermitent behaviour.
Overall are you happy with this product?
- toeApprentice
No fix yet. I have raised a case with Netgear support. However no response.
