simkhye
Feb 06, 2017Aspirant
Router synch with satellite
I just bought an Orbi kit from Costco. It worked perfectly but I only needed one satellite. If I buy another router, can I synch the satellite from the Costo Orbi with the new router in another loc...
- Feb 07, 2017
You can buy the router by itself at Best Buy and I think through Amazon. And yes, you can synch your spare satellite to it as others have said.
Hydro130
Feb 06, 2017Luminary
I don't believe you can buy just the router alone, well a NIB one anyway... Maybe on ebay, I suppose.
Why not return the 3-pack, and just get a 2-pack instead?
Hydro130
Feb 07, 2017Luminary
Hydro130 wrote:I don't believe you can buy just the router alone, well a NIB one anyway... Maybe on ebay, I suppose.
I am an idiot. Yes, you can indeed readily buy a standalone router unit - my apologies for the confusion.
