mukherjeeprabal
Aug 07, 2021Aspirant
Router WNR614- Old router to replace with ORBI AC3000
Hi, need to replace the old router (WNR614) having cable connection of Alliance broadband, want to replace with AC3000 Orbi Mesh, please suggest the procedure.
Thanks
Did you actually remove the old router and replace it with the new RBR and power OFF the ISP modem for 1 minute then back on?
Does your ISP require any user account information or entry on the old router that the new router needs?
Make contact with the ISP to have them help you get the new router online with there modem.
Follow the online user guide and manuals to get the Orbi online...
1. remove old router
2. power off modem
3. power modem back on after a 2 minute wait
4. connect new router
5. power on new router
6. setup new router following the install guide.
install guides can be found here: https://www.netgear.com/support/product/RBR50
for the RBR50
- mukherjeeprabalAspirant
Thanks, but the device connected once to the internet then onwards showing offline, though old router is still working fine. Suggest pls what may be the probable reason.
Thanks
thanks it is working ¡¡
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
