SteCar
Jul 23, 2019Follower
ROUTER/SATELlITE COMPATIBLITY
Can you please tell me which Orbi Satellites are compatible with the Orbi RBR 40 router? I have the RBK 43 mesh system and looking to add another satellite?
thanks
stecar
Most RBS20,30 and RBWs are compatible. Even the RBSY outdoor is compatbile though the back haul rate wont be as good as if it was connected to a Orbi 50 series system. You can even connect a RBS50 to a RBR40. Again the backhaul will not be as good as the 50 series system. It works though.
SteCar wrote:Can you please tell me which Orbi Satellites are compatible with the Orbi RBR 40 router? I have the RBK 43 mesh system and looking to add another satellite?
thanks
stecar
1 Reply
thanks
stecar
