Loulabell
Jun 28, 2019Aspirant
Satalite won't connect after I followed all you posted. RBR50
I read the message board that was running here. I've tried everything that was mentioned. I still can't get my satalite orbi to connect. I'm getting real tired of this.
Was the FW updated on the RBR before the RBS?
What is the Mfr and model# of the ISP modem the NG router is connected too?- LoulabellAspirant
Try a factory reset on the RBS and then press the sync button on the RBR then RBS and see if it will be re-added. Do this while in the same room as the RBR.
What is the Mfr and model# of the ISP modem the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
