Joboo7777
Mar 11, 2019Apprentice
Satellite 5ghz backhaul details
Hello,
I am trying to find RSSI or dBM signal details for the connection between my Orbi router and satellite. Is this information available?
thanks
ekhalil
Mar 11, 2019Master
Please use the following telnet command from the router:
root@RBR50:~# cat /var/satellite_device_info
"mac address": "78:C2:94:xx:xx:xx",
"ip address": "192.168.1.2",
"module name": "RBS50",
"serial number": "xxxxxxxxxxxxxxx",
"signal strength": "-97",
"current version": "V2.3.0.32",
"backhaul status": "1",
"device name": "Orbi Satellite-1"
Joboo7777
Thanks for this. Is there a setting I need to configure to allow telnet to router? I looked thoughout the router webportal but cant seem to find where I enable telnet access.
Thanks
- FURRYe38Mar 11, 2019Guru - Experienced User
routeripaddress/debug.htm
- ekhalilMar 12, 2019Master
To enable telnet in your Orbi Router:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 (or your router's IP address) and enter admin and the same password that you used to login to Orbi
