Joboo7777
Mar 11, 2019Apprentice
Satellite 5ghz backhaul details
Hello,
I am trying to find RSSI or dBM signal details for the connection between my Orbi router and satellite. Is this information available?
thanks
Joboo7777
Thanks
Joboo7777
one more question is the siginal strength measured in -dBM?
- ekhalilMar 12, 2019Master
Yes, so in the example above, I have -97 dBM.
- schumakuMar 12, 2019Guru - Experienced User
That's seriously workable? I would have stated anything in Wi-Fi from -90 dBm and up is unuseable.
schumaku wrote:..........
:) True. I have Ethernet backhaul between router and this satellite and I think that's why the signal strength is not relevant here. I believe if you use this command on a wireless backhaul you would get better values.
