Orbiuser24
Oct 29, 2017Tutor
Satellite connecting at 2.4 Mhz
I recently bought the RBW30 (firmware V2.0.0.34_1.0.21) wall satellite to add to my ORBI network. It has connected to the router (RBK50, firmware V2.0.0.74) but at 2.4Ghz not 5GHz. see following pic;...
- Oct 30, 2017
Problem solved. Factory reset corrected problem and updated region from Europe to Australia correctly.
Orbiuser24
Oct 29, 2017Tutor
Not sure why this image is not showing for you. Works find for me...
The backhaul, if I understand you the connection from the orbi wall plug satellite back to the router, shows a wireless connection symbol with the upper part in blue (2.4 GhZ) and the bottom part greyed (looks like the 5 GHz section)
Orbiuser24
Oct 30, 2017Tutor
