JanAloha
Jan 20, 2019Aspirant
Satellite in a Cabinet?
Can my Orbi satellite be located within a cabinet, or do I have to leave it exposed?
ekhalil
Jan 20, 2019Master
If you put the satellite in a cabinet you will reduce it's fronthaul range (the coverage area where your devices can have access to the satellite wifi) as well as it's connectivity to the router if you have wireless backhaul. So you must take this into consideration.
It depends also on the material of the cabinet, a metal cabinet is much worse than a wooden one.
- CrimpOnJan 20, 2019Guru - Experienced User
Another consideration is heat and air flow. Modern electronics can take a lot of abuse, but sealed tightly inside a small cabinet is a recipe for failure.
- ekhalilJan 21, 2019MasterCorrect. Heating and air flow is important, but can be compensated with fans in the cabinet.
I have my tv boxes (blu-ray, cable tv receiver, satellite receiver, wii,....) in a cabinet and I have a temperature-controlled fan inside to overcome the heating and help with air flow in the cabinet.
