Jeffgear's avatar
Jeffgear
Virtuoso
Aug 21, 2024
Satellite IP addresses
I noticed in the device table in the web UI that the IP addresses that have been automatically assigned to my three RBS50 satellites connected via WiFi bak haul are all 192.168.1.250 which seems odd as this would infer there was a clash of IPs. However everything is working fine.
  • plemans's avatar
    that is a bit odd. A simple reboot of the primary router change the IP addresses?
    • Jeffgear's avatar
      Jeffgear
      Virtuoso
      Firmware 2.7.5.4 for all except for the outdoor that is 2.7.4.12 and I’ve rebooted them all a few times.
      I went into the DHCP config and added one of the .250 as a reserved IP then added each other the others as .249 and .248 which sort of worked - but with two adamant to remain as .250. A reboot at that point now has them on unique IPs from .247.
      What is odd is why they all happily coexisted as duplicates - is this a feature of wireless backhaul or just a UI reporting quirk?
      • FURRYe38's avatar
        Looks like bad behavior...or in a bad state...
