jonmell's avatar
jonmell
Guide
Aug 25, 2021
Satellite issue on Orbi 6
Hi - I have an Orbi 6 RBR850 and two RBS850 satellites.
All working fine for a year or so then had to do a factory reset of the entire system to fix a password issue.
Now one satellite is working fine but any devices connceted to the second satellite won't connect to the internet.
 I can see some differences in the app:
The satellite that doesn't work has a green dot but a different icon to the on that works
The hardware version is blank on the one that doesn't work / RBS850 on the working one
The firmware version is blank on the one that doesn't work / v3.2.18.1 on the working one
The reported serial number on the one that doesn't work is the same as the router. The working satellite has a unique serial number
I suspect the factory reset didn't really work (I've tried it twice) or something went wrong as it kept the name I had given it (Kitchen Satellite). The working satellite reverted to Orbi-Satellite after the factory reset.
Is there an even harder factory reset I can try? Or any other ideas?
  • Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
