blakejnd's avatar
blakejnd
Satellite lights turning on constantly
I find that the satellite lights (on top) are constantly on.  The good news is that most of the time, it is blue, but this is happening often.
It can be especially annoying at night.  And yes, it does flash amber occasionally.
I will normally re-sync or reboot.  I just did not know if this was an issue.
Thoughts?  Thanks!
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello blakejnd,
    Sorry to hear that your satellite is constantly on. May I ask if this is occurring only with the satellite? Also, have you tried unplugging and plugging back the unit?
    Christian
    • blakejnd's avatar
      blakejnd
      Thanks for the reply!  Yes, it is only the satellite.  The main unit does not seem to be having this issue.  I have turned it off and on a number of times, but the issue persists.
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the Mfr and model# of the IP modem the Orbi is connected too?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    Thoughts?  Thanks!
    • blakejnd's avatar
      blakejnd
      FW is V2.1.4.6_1.0.8
      The modem is the new Orbi w/ modem.
      Home is only about 1000 sq ft with the satellite about 30 feet away maybe at most.
      I am using Auto.  So you are saying set up the satellite on its own channel right?
      Sorry if I sound dumb, but I am not super sophisticated when it comes to routers and modems...
      • vkdelta's avatar
        vkdelta
        Please post a screenshot of ATTACHED devices here. Is your satellite connection on 5GHz? Is it shown as "GOOD" ?
  • FURRYe38's avatar
    No the Stallite follows the base router.
    Try setting a manual channel 1, 6, 11...
