packling
Mar 07, 2019Aspirant
Satellite not working every 5 mins
Hi,
I have just bought a RBK 50 router and satellite and both upgraded to firmware V2.2.1.210. My satellite seems having problem and our device can't find the wifi signal every a few minutes. Once it is connected back, the internet connection works again after one minute. Do anyone know why?
I tried to disable the Daisy-Chain Topology. It doesn't help at all.
thanks.....Pack
- The SW 2.2.1.210 has issues with Ethernet Backhaul and handling of wired devices in general. Please disable Daisy Chain if you stay on 2.2.1.210 since there is an issue when you have Ethernet Backhaul and enable Daisy Chain at the same time.
- It's also recommended to go for the latest 2.3.0.32 where quite few wired LAN issues are solved.
- What other devices do you have attached to your network? What wired devices do you have connected to your Router and Satellite?
Is the Orbi system operating in Router or AP mode?
Was a factory reset performed after updating firmware?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
- packlingAspirant
Thanks for the prompt reply. Please kindly find below my setting.
What is the Mfr and model# of the ISP modem the NG router is connected too? Sorry, I don't know the answer as they only provide me a CAT5 cable.
Is the Orbi system operating in Router or AP mode? Router mode
Was a factory reset performed after updating firmware? No
What is the size of your home? Sq Ft? Around 1000 sq ft. but my apartment has a few concrete wall. The router and satellite are connected with LAN and they are located around 30 feet apart.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Auto for 2.4G and 36 for 5G. This is the default setting.
Any Wifi Neighbors near by? If so, how many? I can find 10 other SSID nearby.
What WPA security modes are you using? WPA2-PSK [AES], again default.Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings. Just did it but the discconnection still exists.
Disable Daisy chain.
