SteveW25561
May 21, 2017Initiate
Satellite (RBS50) loses connection and won't reconnect reliably
I'm quite frustrated with my Orbi system: after getting the Satellite connected (blue light, appears on the connected devices screen), the satellite will then seem to drop the connection. It will glo...
Michaelsoft
Jun 23, 2017Star
I have the same issues. Even when I hard wire my PC to the satellite it still doesn't work reliably, and that's putting it nicely. It's to the point where it's unusable and I'm running out of patience. What's weird is I've had the Orbi system for months and it worked great up until a few weeks ago. I feel like they really messed something up with some of their latest firmware updates. I had disconnect issues but no where near as bad as the problems I have now.
Currently I'm waiting on beta access so I can try that. If the beta doesn't resolve these issues I'm moving on to something else.
