SteveW25561
May 21, 2017Initiate
Satellite (RBS50) loses connection and won't reconnect reliably
I'm quite frustrated with my Orbi system: after getting the Satellite connected (blue light, appears on the connected devices screen), the satellite will then seem to drop the connection. It will glo...
krishnaswami
Dec 31, 2017Aspirant
I am having similar issues, I have two satelliotes. When I sync them, the satellite just keeps flashing white.
All my connected devices (iPhones, iPads) keep losing internet connectivity. This just started happening 2 days ago., I have been trying to reset and re-pair all the connections but to no avail. Can you help?
DarrenM
Jan 03, 2018Sr. NETGEAR Moderator
Hello Krishnaswami
Does the router have the same firmware version as the satellites?
DarrenM
