Thomas-EQTR's avatar
Thomas-EQTR
Satellite Recommendation
I can't even find it on the model drop down lol
I'm looking for Satalite recommendation for an RBK40 system, I only need a satellite the will work with this mesh please.
Kind Regards,
Thomas
    Kind Regards,
    Thomas
    Every model of Orbi satellite is compatible with every Orbi router.
    • CrimpOn's avatar
      CrimpOn
      I think that is almost correct.  Only Orbi AC satellites from the residential product line are compatible (not "Pro", not "AX") except for the RBS10, which is a "dual band" product rather than a "tri band" product.  This is frustrating because the RBS10 is the least expensive satellite that is readily available now that Amazon has raised the price on the RBS40V from $100 to $160.
      • vajim's avatar
        vajim
        Master
        Thanks for the clarification
  • Thanks chaps, so this one would be pretty much good then?
    Netgear Orbi RBS20 Wi-Fi Range Extender
    Also, am I able to mark both your answers as Accepted? I figure the points should be split
