Nisheel
Dec 25, 2017Aspirant
Satellite refuses to connect to router
Hello there, I had a router+satellite system paried and working fine. I had to turn off my satellite as I needed to use that plugpoint. When i started it again, the satellite refuses to connect a...
DarrenM
Dec 28, 2017Sr. NETGEAR Moderator
The satellite could be on a different firmware version from the router can you try to connect a ethernet cord directly to the satellite and try to connect to it using 192.168.1.250 and then if you can log in do a manual update of the firmware.
DarrenM
DarrenM
Jan 03, 2018Sr. NETGEAR Moderator
is the 192.168.1.251 the Ip you are using to ping that unit?
