OlivierAlsace
Dec 30, 2020Aspirant
Satellite showing as disconnected on Web app but as Connected on iOS and is working normall
Hi,
I have a RBK20 + 2 RBS20 (Basement and 1st Floor). Originally both satellites were connected in wifi and it was all good.
For a few weeks I have the following issue after having connect 1 (1st floor) of my 2 satellites in ethernet.
1) When connected to Orbi Router Web App, I can see that my Basement Satellite shows as disconnected.
2) When I connect to the iOS, I can see the Basement Satellite being connected to teh Router.
3) If I connect to the Basement Satellite using my web browser and the IP address, it work
4) When I look at the list of connected devices, it shows some devices that are connected which in fact are not and some not connected that in fact are (eg my NAS or the Mac I am using to write this post that have reserved address !)
I tried rebooting (both router and satellite), connecting teh 2nd satellite in ethernet, etc.. but no change.
I see similar issue and so wondering if a factory reset is needed ?
Thanks
Olivier
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteIs Daisy Chain enabled? If it is, try disabling it. I'd power cycle the RBS as well after the RBR reboots.
- OlivierAlsaceAspirant
I disabled the Daisy Chain and all is back to normal.
THANKS
Glad that workied. Please mark your thread as solved so others will knowl.
Enjoy. :smileywink:
