KenM37
Mar 17, 2020Follower
Satellite shows disconnected
I have a RBK50 with 2 RBS50 satellites. all running Firmware ver 2.5.1.8. Logging in from the desktop to local IP URL shows both Satellites as Disconnected. From the phone (Android) app they both sho...
Mar 20, 2020Guru - Experienced User
Are they connected wirelessly or wired?
Are you setting them up in the same room as the RBR first or remotely?
KenM37 wrote:I have a RBK50 with 2 RBS50 satellites. all running Firmware ver 2.5.1.8. Logging in from the desktop to local IP URL shows both Satellites as Disconnected. From the phone (Android) app they both show connected. I've tried removing and adding back with no change. The LEDs on the satellite shows white flashing then blue for 2 mins then out. So it appears to have set up ok.
What am I missing or doing wrong.
Ken
- Ranger54Apr 14, 2020Aspirant
I have a RBR50v2 with 2 RBS50v2 satellites. all running Firmware ver 2.5.1.8. Logging in from the desktop to local IP URL shows both Satellites as Disconnected. This happened after I upgraded to 2.5.1.8. I did a reset on both satellites and then synched them ( in the same room as router). Received a blue light on both satellites but it stills shows disconnected when I log back in through the URL. Any suggestions?
- FURRYe38Apr 14, 2020Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
Ranger54 wrote:I have a RBR50v2 with 2 RBS50v2 satellites. all running Firmware ver 2.5.1.8. Logging in from the desktop to local IP URL shows both Satellites as Disconnected. This happened after I upgraded to 2.5.1.8. I did a reset on both satellites and then synched them ( in the same room as router). Received a blue light on both satellites but it stills shows disconnected when I log back in through the URL. Any suggestions?
Distance from Satelitte is 6 feet. Factory reset was done on satellites. Have not tried reset on RBR
- CrimpOnApr 14, 2020Guru - Experienced User
This is my personal opinion, but it appears to me that Netgear has put customers in an awkward position where some of them have to choose between:
- The latest firmware, which addressed some specific issues, but which also (again, for some users) simply has garbage in the "Attached Devices" information, and...
- The previous firmware, which had rock solid device information but caused caused problems in very specific areas.
So, which do you value more: (a) "getting on with life" and using the Orbi, or (b) having the Attached Devices information be correct?
If the satellites light up "Blue" for 2 minutes and WiFi devices places close to them appear to function correctly, it's pretty obvious that the Attached Devices information is incorrect.
And yet we have some where it does work:
