ChinoMorales's avatar
Mar 01, 2020
Satellites and wall plug in
God day to all,
I would like to know if it’s possible to connect 3 satellites and also add a wall plug-in to my router, I’ve heard that only 3 satellites per router are allowed.
Thanks a lot in advance.
  • CrimpOn's avatar
    CrimpOn
    Users on this forum have reported up to six satellites on one Orbi system.  If my memory is correct, I believe the technique is to power off an existing satellite, add the new one, and then power up the existing satellite.  Now, "there are four!"  To add a fifth, power down two, add one, power up those two.  Now, "there are five!"
    I have not done this myself.  Alas, my palatial home is "overserved' with one RBR50 and one RBS50.
  • I have the AC2200 Orbi Router and satellite installed, want to add an additional satellite...when I added the 2nd..my wifi speed slowed down to near nothing....without the additional satellite, my wifi speed is d/load 225 and upload is @ 11.  What could cause the downgrade in speed with additional satellite?
    Thanks
    • FURRYe38's avatar
      FW versions same across RBR and RBSs?
      Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
      What was the reason for adding a 2nd RBS?
      Thanks
