1993rx7
Sep 27, 2017Tutor
Satellites disconnect
Hi I’ve had a 2 satellite Orbi system since February and for the most part I’ve had a good experience. I first had to force the 2.4g channel to 11 (least crowded) and set my sonos net channel to 6. I’...
st_shaw
Sep 27, 2017Master
Orbi tries to use 40 MHz channels on 2.4 GHz. Unless you have checked 20/40 MHz coexistence, the two will interfere with each other using 6 and 11. So, you'd be better off using channel 1 for Sonos and channel 11 for Orbi, or vice versa.
1993rx7
Sep 27, 2017Tutor
Thanks for the advice, but before Tuesday this week I could stream unique uncompressed streams from Deezer to 6 sonos speakers without dropouts, while the kids were watching YouTube and playing Forza. So although there might be interference it must not have caused enough lost data to be a problem. When the ORBI works it is amazing at how much data it routes without hiccups to 20 plus devices. But when a satellite drops the whole system crumbles. If there was a way to troubleshoot the signal strength, I could at least begin to troubleshoot the issue.
