Elvisj
Feb 11, 2017Star
Satellites do not connect
I have 4 satellites. All. 4 show in device list and all went through proper light sequence during install. But dashboard shows only 2 are connected. So when I select add a satellite, it shows the 2 already connected but cannot find the other two even though one is sitting 12 feet away. How would it know the MAC address if it cannot see them to connect?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Elvisj
You may want to try and power off the units that are already connected and then try to sync the other ones.
https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite?cid=wmt_netgear_organic
DarrenM
