RJA1971
Jan 02, 2018Aspirant
SATTELITE DROP-OUT RBR50 FW2.1.1.16
SATTELITE DROP-OUT I have the RBR50 router and three satellites. I have used the RBR50 ROUTER and AP modes. In AP mode my ISP router modem is in MODEM mode with WiFi disabled, and stiil I have many...
- Jan 02, 2018
We (fellow Orbi users) are well aware of the issue. There's a 13-pages-and-counting thread in this same forum describing the mountain of problems we've experienced with 2.1.1.6 - including the same issue that you mentioned: all devices started connecting to the base unit, irrespective of proximity to any of the satellites.
After struggling with 2.1.1.6 for several frustrating days, I just rolled back my base unit and satellites to the previous stable firmware (2.0.0.74). So far, it seems to have restored connectivity to the satellites: the configuration page shows a pretty normal clustering of devices to the nearest unit.
As for selling out and switching to Google or another provider... it's certainly tempting after this latest update, and at least a few users have done so. I understand that firmware is a difficult task and mistakes happen, but Netgear's almost complete lack of response is extremely off-putting. I'm looking at Velop and some other systems as a replacement, while also waiting for Netgear's response to this incident.
sfsdfd
Jan 02, 2018Star
Stev3D
Jan 02, 2018Luminary
If you do roll back, let me recommend you go with v2.0.0.76. It is a "hot fix" beta update to 2.0.074 that addressed the KRACK issue (so your base-to-satellite communications can't be intercepted). I can't tell you where to find it anymore, but I learned about it from another thread (so seach around here). It is the version I've been using for a few months, and it has been very stable.
- tagteamJan 02, 2018Virtuoso
- RJA1971Jan 02, 2018Aspirant
Many thanks. Sorry to be a pest, but when you buy something so well reviewed and hyped, you can be forgiven for thinking that it maught work.
Ill down-date tomorrow.
RJA
It looks like this the way to go. Thank you for your contribution, I'll downdate tomorrow, and let you know.
RJA
