RJA1971
Jan 02, 2018Aspirant
SATTELITE DROP-OUT RBR50 FW2.1.1.16
SATTELITE DROP-OUT I have the RBR50 router and three satellites. I have used the RBR50 ROUTER and AP modes. In AP mode my ISP router modem is in MODEM mode with WiFi disabled, and stiil I have many...
- Jan 02, 2018
We (fellow Orbi users) are well aware of the issue. There's a 13-pages-and-counting thread in this same forum describing the mountain of problems we've experienced with 2.1.1.6 - including the same issue that you mentioned: all devices started connecting to the base unit, irrespective of proximity to any of the satellites.
After struggling with 2.1.1.6 for several frustrating days, I just rolled back my base unit and satellites to the previous stable firmware (2.0.0.74). So far, it seems to have restored connectivity to the satellites: the configuration page shows a pretty normal clustering of devices to the nearest unit.
As for selling out and switching to Google or another provider... it's certainly tempting after this latest update, and at least a few users have done so. I understand that firmware is a difficult task and mistakes happen, but Netgear's almost complete lack of response is extremely off-putting. I'm looking at Velop and some other systems as a replacement, while also waiting for Netgear's response to this incident.
Stev3D
Jan 02, 2018Luminary
If you do roll back, let me recommend you go with v2.0.0.76. It is a "hot fix" beta update to 2.0.074 that addressed the KRACK issue (so your base-to-satellite communications can't be intercepted). I can't tell you where to find it anymore, but I learned about it from another thread (so seach around here). It is the version I've been using for a few months, and it has been very stable.
