netadmn
Apr 18, 2018Apprentice
sattelites disconnecting users, arp showing 192.168.1.250 flip flopping between sattelites
I have the RBK53 system. I have it setup in AP mode with the base router setup with ip address 192.168.1.2. I have DHCP reservations for my satellites to get IP 192.168.1.3 and 192.168.1.4. My cl...
Apr 18, 2018Guru - Experienced User
After updating FW, did you factory reset the router and all satellites then set up from scratch? Please do this if you haven't.
Are these satelllites using wired or wireless back haul?
Any Network switches in between the satellites and router?
Whats the distance between the router and satellites? Recommend starting at 30ft minimum in between.
Whats the SQ ft of your home?
Any wireless neighbors near by? If so, how many?
