imaz
Mar 02, 2020Aspirant
Scheduled Reboot - crond and cronjob
Hi, There is no option for a scheduled restart of the router through the Web Interface, although each router should have this option by default as a weekly restart of any router is almost require...
imaz
Mine seems to perform slow over wifi devices, drops out of simply doesn’t want to route traffic. It’s even worst when my kids play their pc games and the satellite takes higher priorities over clients as the pc is connected over Ethernet on one of the satellite.
I mainly use the Orbi(RBR50) as an AP, with 3x Satellite (2x RBS50, 1xRBV40), and my main router is an Asus RT-AC88U. Simply because the Asus has a better router management interface.
I just realised although I can schedule the reboot over a cronjob, the telnet and cronjobs are not static! I still need to enable telnet after the reboot, and need to re add the cronjob....
Mar 02, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration? or directly wired to the host router?
I presume all wifi is turned off on the main host router.
What other wifi devices do you have running?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
