ed1968's avatar
ed1968
Tutor
Nov 19, 2020
Scheduling Firmware Update on RBR50/RBS50
Hi Everyone,
I am comtemplating scheduling firmware updates on my router/satellite.  Couple of questions:
1) is this a good idea?  normally I like to supervise an update and unattended scares me a bit.
2) do I accomplish this via the Scheduler in >>>Advanced>>Security>Schedule by unblocking the time for it to occur ie. 0100-0400hrs?
Thanks in advance,
Ed
  • FURRYe38's avatar
    ed1968 wrote:
    Hi Everyone,
    1) is this a good idea?  normally I like to supervise an update and unattended scares me a bit. No.
    FW updates can't be scheduled.
    • ed1968's avatar
      ed1968
      Tutor
      I was informed by Netgear that they typically push out new firmware updates between 0100-0400hrs.  If you block services via the Scheduler on certain days/times you should be limit when the updates to firmware will be installed.
      Am I seeing it correctly?
      • FURRYe38's avatar
        You can give it a try. Did they tell you how to configure this?
