cyberprashant
Nov 28, 2016Luminary
Seamless Roaming Orbi
So far impressed with the orbi system.
Satellite firmware update was glitchy using Chrome, but worked fine in IE. I did update manually.
Seamless roaming appears to be happening. You can actually pull up each satellite by it's IP (see attached devices - or in firmware update it will display the IP when the load firmware box appears) for the satellites). I can see that as I move from one end of the house to the far end other side, the iPhone (with its screen on whole time) will now be connected from one satellite to the other one. Facetime/video seems to be working fine as well roaming across access points! Speed seems impressive so far....300 mbps actual transfer rates for a file from HDD across network to SSD (approx 35 feet from nearest node)
impressed as this is working much better than my 2 router setup (r8000 and r7000 connected via ethernet backbone). For roaming there I had to switch the screen off or toggle wifi
A wifi extender didn't work well - created too much lag (Linksys RE6700/6400)
just to clear something up the orbi is NOT seamless roaming , it has band steering and ap steering but thats not technically seamless roaming
the client device stiull disconnects from one transmission to then move to another
real seamless roaming does not disconnect at all
- cyberprashantLuminary
Perhaps not true commercial grade seamless, but if you have an iPhone 6 or more try an app called Netty - it will show u the mac id of which host your connected to. I can run this on one side of the house, then run speedtest while quickly moving to the other side of the house and close netty and reopen it and I get a different mac ID for the closest satellite node with the screen never switched off and no loss in speedtest. I noticed though my old android samsung tablet likes to keep latched to the same MAC ID (On android a great program is Wi-Fi Analyzer).
So do any of the mesh solutions out there offer true commercial grade seamless, or is it AP steering as above? Thanks.- rhester72Virtuoso
cyberprashant wrote:
So do any of the mesh solutions out there offer true commercial grade seamless, or is it AP steering as above? Thanks.Currently only Ubiquiti's UniFi (note: NOT the same thing as AmpliFi!).
Rodney
- Miles267ApprenticeWhat is beamforming exactly? What are the benefits of enabling or disabling it in Orbi?
Re: zero handoff I've also used multiple Open-Mesh APs prior to Orbi and found fewer Orbi units actually handoff more reliable than OM. This was a pleasant surprise.- RonV42Luminary
A very good brefing on what Beamforming is:
https://en.wikipedia.org/wiki/Beamforming
Due to "stickyness" in some wireless devices Netgear left Beamforming turned off in the Orbi. I found that older devices have more issuess jumping from satellite to satellite when turned on. I have a 3 year old Android tablet that refuses to release from the Orbi on the far end of my house when beamforming is turned on. Turned beamforming off and the tablet now moves from sat to sat.
