ryanjohn04's avatar
Aug 01, 2017
See which devices using Router WiFi (not Satellite)
I understand how to see which devices are connected to the Satellites (take the IP address from the main Attached Devices page and enter into a browser).  How can I see which devices are connected directly to the router?  If I use the .1 router address it always brings me to the main OrbiLogin page.
Thanks
  • Hello ryanjohn04
    Process of elimination would be the way to figure it out  whatever is not connected to the satellite will be whats connected to the router. Sorry this isnt a very clear way to do it.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello ryanjohn04
    DarrenM
    • ryanjohn04's avatar
      ryanjohn04
      Guide
      Thanks Darren- would think its a pretty easy thing to add to the connected devices, a column which shows whether its a satelitte (and which one) or the main router.  But appreciate the answer and makes sense.  Thank you
