ryanjohn04
Aug 02, 2017Guide
See which devices using Router WiFi (not Satellite)
I understand how to see which devices are connected to the Satellites (take the IP address from the main Attached Devices page and enter into a browser). How can I see which devices are connected directly to the router? If I use the .1 router address it always brings me to the main OrbiLogin page.
Thanks
Hello ryanjohn04
Process of elimination would be the way to figure it out whatever is not connected to the satellite will be whats connected to the router. Sorry this isnt a very clear way to do it.
DarrenM
- DarrenMSr. NETGEAR Moderator
Hello ryanjohn04
DarrenM
Thanks Darren- would think its a pretty easy thing to add to the connected devices, a column which shows whether its a satelitte (and which one) or the main router. But appreciate the answer and makes sense. Thank you
